How to send the xml data to datatable
How to send the xml data which is stored in the system to datatable
Hi Sameera,
My first thought would be to use the following universal converter tool found using the link:
https://marketplace.thingworx.com/tools/Universal-converter
Use the tool to convert from xml to an infotable using the provided service ConvertXML & then you would just need to get the data from the infotable into a DataTable. You can achieve this using pretty straight forward javascript - you may want to use a for each loop to write the infotable rows to a datatable.
Hope this helps.
Andy
