how to set rows with custom order in dropdown Thingworx 9.1.1
Hi ,
I have Datatable which contains 20 rows and i have written service which fetch Machine names from this Datatable and displays in Dropdown , but i want order of rows same which is in Datatable. how to achieve this. if we manage it at dropdown also No issue.
Vaibhav
PaiChungAnswer
22-Sapphire I
If you need to enforce an order, I recommend you add an order field to your DataTable (assuming there is no suitable field to order on available) and then apply sort to that order field.
22-Sapphire I
In your service that fetches the data, apply a Sort
Hi @PaiChung ,
If we sort in Service, it will return either Ascending or Descending. I want custom order that is how I have inserted in Datatable
in same order dropdown list should hold. If you elaborate more on this , would be better.
PaiChung22-Sapphire IAnswer
22-Sapphire I
