May 26, 2016 7:28 PM UTC
How to set up a reverse proxy with organization structure?
I am trying to put in place nginx as a reverse proxy to hide the thingworx's URLs.
I use this configuration for nginx:
    server {
        listen       80;
        server_name  localhost;
          location /MyApp {
               proxy_pass http://localhost:8080/Thingworx/FormLogin/MyAppOrg;
               proxy_set_header Host $host;
               proxy_set_header X-Real-IP $remote_addr;
It works fine for the login page of the organization but the Home Mashup cannot be displayed, I got an 404 error.
To solve it, I need to add this rule:
          location /Thingworx {
               proxy_pass http://localhost:8080/Thingworx;
But by doing this I didn't mask anything, I can see the full internal url in the address bar after logging...
Does anyone know how to setup a reverse proxy with organizations ?
May 26, 2016 7:56 PM UTC
Fabien, can you post your .conf file? With your location set as /Thingworx, all the proxy_pass flag would need is host:port.
fserre1-VisitorAuthor
May 26, 2016 8:13 PM UTC
Thanks AAnjan for your answer. I've modified the .conf file as followed:
worker_processes  1;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    keepalive_timeout  65;
    server {
        listen       80;
               proxy_pass http://localhost:8080;
          location /MyApp {
But once logged, I am still redirected to : http://192.168.73.128/Thingworx/Runtime/index.html#master=MyAppMain&mashup=WelcomeScreen
May 26, 2016 8:22 PM UTC
Since you have the location for /Thingworx, can you remove the /MyApp one and retry? So that your server section would just have location /Thingworx.
Here's an example configuration I've used before:
server {
    listen      80;
        location /Thingworx/WS {
            proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
            proxy_pass http://thingworx_server;
            proxy_http_version 1.1;
            proxy_set_header Upgrade $http_upgrade;
            proxy_set_header Connection "upgrade";
            include /etc/nginx/conf.d/acl.default;
            allow a specific ip;
            allow 127.0.0.1;
            deny all;
        location / {
            add_header Access-Control-Allow-Origin *;
            allow 127.0.0.1;
            deny all;
I've added the upgrade headers to allow EMS websocket connections as well. My setting was was specific to allow any connection that would hit /Thingworx/WS (primarily used for Edge connectivity).
