Jamal Ashraf
Jul 31, 2024 4:41 AM UTC
how to show datagrid widget properties permanently on mashup
Hello All,
      I have a datagrid widget in which i am showing some entries as you can see in the picture below i can choose which parameter to show and which do not. when i select the parameters and save changes then it appears and shows me but then when i open the mashup next day again then its again gone and do not show me the parameters which i have selected to display on the mashup in datagrid. I want the parameters which i selected to show me always there until i do changes. anyone has an idea about it?
Jamal Ashraf
Aug 19, 2024 8:48 AM UTC
Hi @Velkumar
Thank for your reply but i have found my solution in the settings (small wheel icon when selected gridadvanced widget). There you can choose which parameters for the datagrid one wants to show and which do not so thats a solution of my question.
Jul 31, 2024 6:06 AM UTC
Hi @MA8731174
Column selection feature does not retain the selected once cookies cleared or session expired.
To have it as a feature, you can use dynamic configuration JSON based on user.
More information - Configuring the Grid using JSON Data (ptc.com)
/VR
Jamal Ashraf
Jamal Ashraf16-PearlAuthorAnswer
Hi @Velkumar
Community Moderator
Aug 14, 2024 5:14 AM UTC
Hello @MA8731174,
It looks like you have a response from a community member. If it helped to answer your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
