How to show "No Data" like this in advanced grid widget?
How to show "No Data" like this in advanced grid widget? Kindly refer the attached image.
M4RCAnswer
before your service returns an empty value, you can add a fixed row, which contains a value like "Nothing found".
Best regards
Marc
Very simple. I use a contained mashup (one which has that message in the center), that I switch to. I do not use the Grid itself for this situation.
when there is data for corresponding search, the grid should show all the rows. When there is no data for the corresponding search, we should show no data. If anyone have any idea let me know.
M4RC14-AlexandriteAnswer
Best regards
Marc
This is a bit aside so it will not answer your question but be aware that this behaviour is OOTB with the new grid in 9.3
