Rocko
RockoAnswer
Jun 24, 2024 1:57 PM UTC
Decide if you want to use a number type or a string. the number 0500 has the same value as 500.
You could store as a number and convert it to have a leading zero if you need to display it, or you can store it as a string with the leading zero(es), and parse it into a number when you need to make computations.
Rocko
Rocko19-TanzaniteAnswer
Community Moderator
Jun 28, 2024 3:16 AM UTC
Hello @AP_10343008,
It looks like you have a response on your topic. If it helped you answer your question please mark the reply as the Accepted Solution.
Community Moderation Team.
