How to show rectangular shapes with Text values from data service dynamically
Greetings!
                 I do have a tree structure like Plant --> Module --> Area etc. I want to display all the modules from the selected plant (selected from dropdown) in a rectangular box so that on module click it will show underlying areas(rectangular box with text).
                I have tried repeater widget with shape widget but shape widget showing only first value from data service. I want to display all the values with separate rectangular boxes. Could you please help me.
Thanks.
20-Turquoise
You could try using element CSS or modify existingtree widget to do so.
ras1-VisitorAuthor
Thank you for your response. Could you please elaborate on your solution.
Thanks.
20-Turquoise
You may refer to this for the CSS solution
https://www.ptc.com/en/support/article?n=CS278999
Or look into custom extension development (document attached).
20-Turquoise
