Aug 4, 2021 12:11 PM UTC
How to simulate motion trajectory or motion animation in mashup?
This is a recent learning task of mine. The teacher hopes that we can simulate the movement trajectory of a conveyor belt in real time. I hope someone can help me.
PaiChungAnswer
22-Sapphire I
Aug 5, 2021 12:01 PM UTC
We've done overlapping shapes before to do this.
22-Sapphire I
Aug 4, 2021 1:04 PM UTC
This is very vague.
I would encourage you to first write down the requirements of what it would look like.
What is movement trajectory, what defines a movement.
After that I think you should probably notice what you need to fill in next and that should get you to the start of your simulation needs.
Fusanmu1-VisitorAuthor
Aug 5, 2021 7:40 AM UTC
Thanks.
I have a slider that moves along a fixed path and can read his distance information. I want to know how to simulate his movement in the mashup, so as to observe his movement more intuitively.
Aug 5, 2021 8:23 AM UTC
(NB. never tried to move elements only changed colour and  text values in a svg-image.)
I assume that this is a 2D picture where you present the location.
Have a look at the SVG-widget and use overrides to move an element describing the thing you want to track.
Good luck
Per
