Jul 17, 2017 7:04 AM UTC
How to solve SSLHandshakeException?
Hi all,
I am now using getJSON function to get the content from an url, and the code is shown as below:
var params = {
proxyScheme: undefined /* STRING */,
headers: undefined /* JSON */,
ignoreSSLErrors: true /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: true /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: 'proxy.companyname.com' /* STRING */,
url: "http://gateway-a.watsonplatform.net/visual-recognition/api/v3/classify?api_key=9cf5fa21fe8ff3d9eaa49d0319f329ae5ee7bb89&…" /* STRING */,
timeout: undefined /* NUMBER */,
proxyPort: '8080' /* INTEGER */,
// result: JSON
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
I got the error message below:
Wrapped javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target Cause: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
But when I change the url to https://feeds.citibikenyc.com/stations/stations.json, can get the content.
Can anyone help solve this problem? Thank!
CRArkoAnswer
Feb 28, 2018 4:16 PM UTC
Hi.
With that kind of error reported the cause is often that the certificate is missing from the Java keystore.
Is this a self-signed certificate? If so, try this procedure out:
Import the self-signed certificates from the external server into the ThingWorx trust store using the following steps:
  • Locate trust store used by ThingWorx
    • Enable SSL logging if needed by adding the following parameter: -Djavax.net.debug=ssl
    • Restart Tomcat
    • Review Catalina and stdout logs for the following line:
trustStore is: C:\Program Files\Java\jre1.8.0_141\lib\security\cacerts
  • Download the InstallCert.java script to the ThingWorx machine in the same location as the cacerts file identified above
  • Execute: javac InstallCert.java
  • Execute: java InstallCert externalserver:port
  • The Java application will prompt you to install the external certificate
  • A new jssecacerts should be generated with the external certificates in the same location as the cacerts file
  • Restarting Tomcat will indicate a new trust store: trustStore is: C:\Program Files\Java\jre1.8.0_141\lib\security\jssecacerts
  • Retest the operation that was failing earlier with the PKIX error
Let us know if this is successful or not.
-- Craig A.
yzhang11-VisitorAuthor
Jul 17, 2017 7:06 AM UTC
The API key needs to be updated, but not influence the result.
Aug 16, 2017 4:28 AM UTC
Hi Ying Nang Zhang,
Is your problem resolved? I have a similar problem here.
Aug 29, 2017 3:24 PM UTC
Any response to this? I also am having this problem.
Nov 30, 2017 2:21 PM UTC
Was this on ThinWorx version 8?
I am seeing similar error, not sure what the core issue is?
Feb 28, 2018 12:04 PM UTC
How did you solved the problem?
I am having the same problem.
madhu
Mar 7, 2018 11:11 AM UTC
I had the same problem (EC2 Amazon Linux server, using TWX 8.1 Docker PostgreSQL), and it was not a self-signed certificate. The following worked for me:
Stop ThingWorx:
$ docker stop twxfoundation
Go to https://www.target_address.com/ and click on lock icon to view SSL certificates
Open Certificate and view Certificate Path - download each certificate in that path (Details -> Copy to File). Use first export option (must be X.509 certificate)
Upload downloaded certificates to your ThingWorx server
Import certificates into Docker keystores into TWX server, use following for reference:
https://adamtuttle.codes/TIL-adding-a-jvm-ssl-cert-docker/
https://stackoverflow.com/questions/21076179/pkix-path-building-failed-and-unable-to-find-valid-certification-path-to-requ/36427118#36427118
Find keystores in your TWX server (in my case Docker keystores, with a path that included "/docker/overla2"):
$ sudo find / -iname 'cacerts'
Import each certificate into each keystore, for example (storepass is "changeit" by default):
$ sudo keytool -importcert -alias myApiCert -keystore "/data/docker/overlay2/blahblah123/diff/opt/jdk1.8.0_92/jre/lib/security/cacerts" -file my_api_cert.cer -noprompt -storepass changeit
Mar 8, 2018 7:03 AM UTC
I got this problem, while installing ThingWorx Navigate when connecting to Windchill,
I have solved it importing the Windchill signing certificate into Java Keystore.
madhu
CRArko5-Regular MemberAnswer
Hi.
    • Restart Tomcat
-- Craig A.
Apr 12, 2018 12:58 PM UTC
Hi Craig A.,with "java InstallCert externalserver:port",what the "port"should be?Thanks.
