How to solve the NaN value in updated location field
My code is to get a new field of location from available column longitude, latitude, elevation. Built with no error.
// result: INFOTABLE  dataShapeName : "MapData"
var result = Things["ThingName"].ServiceName(); // Change the ThingName and Service name here
var newField = new Object();
newField.name = "location";
newField.baseType = 'LOCATION';
result.AddField(newField);
// location:LOCATION
var temp = new Object();
var tableLength = result.rows.length;
for (var x = 0; x < tableLength; x++) {
    var row = result.rows;
    temp.latitude = row.latitude;//result.rows.latitude;
    temp.longitude = row.longitude;//result.rows.longitude;
    temp.elevation = 0;
    temp.units = "WGS84";
    row.location = temp;
But the output is like this. The location column is all NaN:NaN. Something is wrong?
qngoAnswer
The "result" in my test is a new InfoTable of DataShape NamedVTQ, created directly in service. Then I added 10 rows with only "value" before adding the new field "location". The "latitude" and "longitude" are just 0,1,2...
var data = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({dataShapeName: "NamedVTQ"});
for (var i = 0; i < 10; i++) {
    data.AddRow({name: "name_" + i})   ;
newField.name = "mylocation";
data.AddField(newField);
var tableLength = data.length;
for (var x = 0; x < 10; x++) {
    var row = data;
    var tmp = new Object();
    tmp.latitude = x;
    tmp.longitude = x * 10;/
    tmp.elevation = 0;
    tmp.units = "WGS84";
// 3 rows below work
//    data.mylocation = tmp;
//    data.rows.mylocation = tmp;
    row.mylocation = tmp;
    data.AddRow({mylocation: tmp, value: tmp.latitude});
    data.value = tmp.latitude;
data.AddRow({mylocation: tmp, name: "name_99", value: 99});
logger.debug(data.rows);
result = data;
Pleas move
inside for loop
other wise you are setting all the location field to one object and do the change on one object
YUanwu Shen
tguo1-VisitorAuthor
My code is like this now:
temp.baseType = 'LOCATION';
    temp.elevation = 0;
    result.rows.location = temp;
My output still the same...
Hi Tiantian Guo​,
row.location = temp;  is incorrect
it should be result.rows.location = temp;
tguo1-VisitorAuthor
In the loop script,
So I think the code is right.
The behavior is weird. Before the end of for loop, if I add "result.AddRow({location: temp}), the new rows are added with correct location. When I log the result, the data structure is different too.
"location" where is Nan: "location={"elevation":1.0,"latitude":1.0,"units":"WGS84","longitude":0.0}"
Correct "location" added at the end of result: "location=1.0,1.0,0.0"
That's Strange because it works fine for me.
The only difference is I am not using the DataBase. My data is stored in a DataTable.
Hi Tiantian Guo​,
Based on Quang input; I have following suggestion:
1. Create a new DataShape which has all the fields you require + location field. DataShape1
2. In custom Service create a new Infotable using above DataShape.
var params = {
    infoTableName: "INFOTABLE" /* STRING */,
    dataShapeName: "DataShape1" /* DATASHAPENAME */
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
3. Loop though the old infotable (let's say result1) and Add the Row to the new infotable (result).
var tableLength = result1.rows.length;
     temp.elevation = 0;
     temp.latitude = result1.rows.latitude;
     temp.longitude = result1.rows.longitude;
     var temp1 = new Object();
     temp1.latitude = result1.rows.latitude;
     temp1.longitude = result1.rows.longitude;
     temp1.location = temp;
     result.AddRow(temp1);
I hope it helps.
tguo1-VisitorAuthor
Dear Ankit,
     I got the right result using your code.
And I attach the result to the google map,
There are nothing appearing.
I thought maybe the precision of the location, there are lacking two digits from the original latitude and longitude..
Hi Tiantian Guo​,
Could you please start a new Thread for this issue and add a Screenshot of Google widget properties.
Have you selected the location column for location property in Google widget?
