How to stop the labview process from thingworx mashup,?
Hello ,
we have integrated the data from labview to thingworx , now we are able to post the data to thingworx properties, so now we are getting real time data in the thingworx mashup which we can say that we are successfully monitoring the data of the machine and displaying it on the mashup (This is now only one directional )
How can we control the labview process from thingworx mashup with emergency button , for example  say if we click on the stop button it should stop the whole process in the labview , if we click on the start button it should start the process in the lab view (This use case is only for emergencies to control the process of the machine from thingworx).
If anyone has the idea on this please help me to solve this.
Shree
Can you expose HTTP endpoints in LabeVIew ? If you can, you can invoke them from ThingWorx, and you can write your logic in LabVIew, when the endpoint gets invoked.
Other ways could be using MQTT or WebSocket.
You can also use, HTTP polling, which is like in LabVIew you continueously invoke a service in THingWorx adn that would respond with theteher the button is pressed or not.
Hope this would help. 🙂
NH_shree14-AlexandriteAuthor
Hi @Bikash_Panda
To post the data from labview to thingworx i have used RestApi POST method where for example
http://localhost:8080/Thingworx/Things/isf/Services/test?method=POST  , are you talking about this as a HTTP endpoints in labview? i am not sure of working in labview because i have not used it before .
Can you please brief it with example !
Shree
Support
Hi @NH_shree.
How are you invoking the post request?  Can you just stop the process?
I think we need more details regarding the process to fully understand the request.
--Sharon
