How to store the Infotable in Thingworx storage instead of Storing in Data base?
I want to store the Infotable data temporarily for some purpose. Is it possible to store the infotable data in Thingworx storage instead of storing in Database.  Kindly let me if there any solution available for my requirement.
Thanks in Advance,
Sankarapandian.L.S
wposner-2Answer
Check out session variables.
raluca_edu
You can store infotable in a property of type infotable (persistent).
Unfortunately, if property is persistent it will be written  in database.
Hope it helps,
Raluca Edu
wposner-21-VisitorAnswer
Support
Hi @Sankarapandian.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
