How to store URL into Infotable?
I am having 2 columns i.e. name, and Download URL.
I want to store both values into Infotable.
so I created a datashape with fields . name (String) , downloadURL(hyperlink)
But, when I store values into Infotable ,only name get inserted , URL is not getting inserted.
why this happens?
I tried with same datashape and test with a www.google.com url, also failed. The Hyperlink recorded it as /Thingworx/MediaEntities/www.google.com, it's looking for an internal resources and that's why it doesn't work.
You should input the url as http://www.google.com, now it could get external access
@zyuan1  I am using a already defined method, I don't need to pass URL as input.
But , the output I get is also A URL. When I store the output in a variable and display it , it gives exact output.
But, when I pass the output to InfoTable , their I don't get output.
Output I get is :
http://gt034.galaxy.com:90/Windchill/servlet/WindchillAuthGW/wt.content.ContentHttp/viewContent/tank_drw.pdf?u8&HttpOperationItem=wt.content.ApplicationData%3A586480&ofn=tank_drw.pdf&ContentHolder=wt.viewmarkup.DerivedImage%3A586468&forceDownload=true
The result URL works in a Link widget but not on a Grid widget, is that what you mean?
