How to style autocomplete widget?
Hello All,
We are using autocomplete widget. We need to change style for the autocomplete widget as well as need to change height & width.
I have tried giving different height & width but at runtime size of autocomplete widget is same as default.
Also there is no option to add style definition.
Can anyone please let me know how to add style definition & change height & width of the autocomplete widget.
Thanks & Regards,
Renuka Patil
For styling I didn't customized it, but for better resizing support yes, here you have our customized Autocomplete widget ( we where on 6.5.X last month, now we are on 7.3.X ) https://www.dropbox.com/s/4r6l342vntfxrpc/Autocomplete_Extension.zip?dl=0
Hi Renuka, On which TW version are you working, if you are on 7.3.6 and above, or 7.4.3 or above List Widget has a new mode which it's "Combo Box" that allows similar features to the old Marketplace Autocomplete widget, maybe with this widget you have more features. If you have to relay on Marketplace autocomplete widget, you will have to think on customizing it for yourself if you want the features you asked for. Best Regards, Carles.
rpatil-211-VisitorAuthor
Hello Carles,
Thanks for your quick response
I am using TW 6.5.0 & marketplace autocomplete widget.
Thanks & Regards,
Renuka Patil
