Apr 22, 2021 3:08 PM UTC
How to trigger a custom event every time a user accesses ThingWorx
Hi Team,
Hope everyone is doing well.
I would like to know how will I throw my custom event each time a user logs in and logs off ThingWorx.
Thanks in Advance.
Jun 1, 2021 10:10 AM UTC
Hi @slangley
Thank you for the response. The current implementation uses a scheduler that monitors the number of users logged in and compares with the users before in a particular interval. This implementation is working currently.
Thank You @BABA-SHYAM those events are very useful I had tried them but the problem was during logging out, there will be users who might not log off in the required manner.
Support
Apr 22, 2021 6:41 PM UTC
Hi @SrijithKrish.
Are you referring to a user logging in to Composer or a mashup?  If you're referring to a mashup, you could design a service to run each time the user logs in.  Logging out would be more difficult since it requires a user to logout elegantly instead of just closing the browser.
--Sharon
Apr 23, 2021 8:14 AM UTC
@slangley , main requirement is to keep track of all the users that are accessing Thingworx within a day (both via composer as well as mashup application), that is I would require to keep history of this data. Currently I am able to see how many people are using but not the history.
Is this requirement possible within ThingWorx?
Apr 29, 2021 4:45 AM UTC
There is a security monitor thing (don't select template with same name) available in thingworx. There you will find a "LoginSucceeded" event under it. This event will work if your user is login by typing the credentials. There is another event available "ApplicationKeySucceeded " if user try to access thingworx using app key. Every time this event occur you can run a custom event.
Regards
Shyam
Support
May 10, 2021 6:32 PM UTC
Hi @SrijithKrish.
Have you found a solution to your issue?  If so, we would be happy for you to post it here for the benefit of others in the community.
--Sharon
SrijithKrish1-VisitorAuthorAnswer
Hi @slangley
Jun 2, 2021 4:37 AM UTC
What is the role of those users? I don't think any such issue could happen while logging out the user. User logs out successfully right? Its only the trigger which doesn't run. Is it happen always? Did you try to debug the issue?
Regards
Shyam
