how to uninstall a failed linux install
The install in linux was interrupted. Now I am getting the dialog
There has been an error.
Previous installation of Thingworx_Foundation is found. Please uninstall the existing installation and then re-install.
I can't seem to find any docs on how to uninstall.
memeletAnswer
I finally got it installed. After trying every combination of update-alternatives and update-java-alternatives, I had to uninstall openjdk-11. Only then would TX use oracle-jdk-8.
So what, 5 hours to install the trial. Good thing I was motivated.
memelet1-VisitorAuthor
I dug around and deleted various directories `*worx*`. Then the install would run again.
But how I get this error dialog, which does not give me much to go on.
Problem running post-install step. Installation may not complete correctly
Error running ./check-http-response --username "Administrator" --password **** --hostname "localhost" --hostport "8448" --useSSL=1: 1
Clicking thru the dialogs results in the main install dialog just saying it "failed"?
Is linux an uncommon install for thingworx?
Found and ran the uninstall script in /opt/twxFoundationH2Trail-8.3.2.
The tried installing again, this time without SSL.
Same error dialog at the end. However there was no install log created this time around.
Was using openjdk, so installed oracle jdk8 and tried again to install...
same error, again no install log (but there was an uninstall log)
