How to update Infotable property using service in extension ?
Hello all,
I'm trying to update Infotable property value using "UpdatePropertyValues" service. When I run the code, I'm getting error as "Unable To Convert From java.lang.String to INFOTABLE". Below is my code,
DataShapeDefinition updatepropertyShape = new new DataShapeDefinition();
updatepropertyShape.addFieldDefinition(new FieldDefinition("name",BaseTypes.STRING)); updatepropertyShape.addFieldDefinition(new FieldDefinition("time",BaseTypes.DATETIME)); updatepropertyShape.addFieldDefinition(new FieldDefinition("quality",BaseTypes.STRING)); updatepropertyShape.addFieldDefinition(new FieldDefinition("value",BaseTypes.STRING)); InfoTable updateproperty = new InfoTable(updatepropertyShape); Calendar currenttime = Calendar.getInstance(); JSONObject values = new JSONObject(); values.put("time", new DateTime(currenttime)); values.put("quality", "GOOD"); values.put("name", "MBT_CapacityOfMachine"); values.put("value", parsedValue); //ParsedValue is Infotable updateproperty.AddRow(values); thingName.UpdatePropertyValues(updateproperty);
I tried using "setPropertyValue" in service, I'm getting error as "com.thingworx.types.InfoTable cannot be cast to com.thingworx.types.primitives.IPrimitiveType"
thingName.setPropertyValue("Prope1", (IPrimitiveType<InfoTablePrimitive,InfoTable>) propertyValue);
Can any one help me to fix this issue ?
VR
I don't know exactly on how do to it with Java extension, but on your code I can see some incongruences:
  • you have a double new new on DataShapeDefinition creation.
  • you are setting value field on the JSON with an Infotable (parsedValue) but you add it to and Infotable that this field is defined a STRING field not an INFOTABLE field --> this may indicate your error.
Velkumar19-TanzaniteAuthor
Hi @CarlesColl,
Thanks for your reply.
1. Double new is typo. It occurred while copying and pasting code in community.
2. When I convert infotable to String using "toString()" function it works fine.
VR
Yes using toString you are converting the parsedInfotable to String again and your value it's of String and then it works as String but not as Infotable, what if you change the field definition for value to INFOTABLE ?
