7-Bedrock
Oct 21, 2023 10:41 AM UTC
How to update the tag value using button widget.
Initially posted in this topic
I am using s7-1200 plc , i want to write the plc tag value from thingworx to kepserver after that plc.  It is a memory tag and boolean.  from remote thing if manually i can set the value true/false, it is changing in kepserver, but through button widget not happening.  How to update the tag value using button widget.  Pls help me out
Oct 23, 2023 9:04 AM UTC
