Rocko
Sep 9, 2025 3:27 PM UTC
Sep 10, 2025 5:07 PM UTC
Not sure if you have TWX Flow? If you have you could use the FTP connector
https://support.ptc.com/help/thingworx/flow/r9/en/#page/flow/flow/FTP/FTPConnector.html#
18-Opal
Sep 15, 2025 9:52 AM UTC
I would mount your remote container via sshfs into /ThingworxStorage/repositories, then just treat it as a local file repo.
/ Constantine
Support
Sep 22, 2025 1:47 PM UTC
Hi @Janaki.Raman
As you have been provided with a few options for addressing your need, it would be appreciated if you could designate the one that worked for you as the Accepted Solution, for the benefit of other Community Members who may have the same question.
Thanks for using the PTC Community!
--Sharon
