How to use a mashup as a master mashup
Hi Developers,
I have a mashup with lots of containers and widgets. I am currently using it as a homepage in Organisation. But it cannot be used as a master in mashups as ThingWorx won't allow that.
I have been asked to copy entire contents of mashup into a new master mashup so that we can use it in mashups as a master.
Its very time consuming. Is there a way to make a mashup a master or a way to reference mashup into master? Any suggestions will be appreciated. Thanks in Advance.
  • Export mashup as XML (Keep backup as well)
  • Search for aspect.mashupType which is inside <Mashup> tag
  • Change the aspect.mashupType from mashup to target
  • Now import again into Thingworx
from
to
from
to
Thanks a lot @Sathishkumar_C!
It worked.
