How to use aggregate service[MIN ,MAX ,AVERAGE ,COUNT ,SUM] on DateTime
Hi
I want to use the aggregates MIN method on TimeStamp[BaseType : DateTime] column
I want output as below:
UserIDTimeStamp
12016-11-16 24:57:27.412
22016-11-16 20:53:28.444
32016-11-16 19:52:26.234
I am taking input as QueryPropertyHistory Service data.
var params = {
  t: MyInfotableInput /* INFOTABLE */,
  columns: "TimeStamp" /* STRING */,
  aggregates: 'MIN' /* STRING */,
  groupByColumns: 'UserID' /* STRING */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Aggregate(params);
You can use getTime() service on DateTime object to get the milliseconds from EPOC time and then you can easily set back to DateTime object with new Date(milliseconds).
You can use the Derive snippet to generate the myDateTimeField.getTime() column.
The aggregate functions only work with numbers.
What you can do is make a temporary infotable with an additional column and calculate the date difference between the timestamp and a fixed date using dateDifference(date1, date2).
This results in a number where the aggregate functions can be used.
The way Carles Coll​ mentioned worked pretty well form me.
done111-VisitorAuthor
Thanks alot Carles Coll​ . It worked !
If your issue is resolved please mark this thread as answered with the right comment/answer.
