How to use date time picker to show data in a table
Hi there,
I have created dashboard with some informations.
I get these information of my PLC through of Industrial Connectivity.
I want to salve these information once a hour to show in a table using the date time picker to insert a range.
To it I have two question:
Is possible salve my information into ThingWorx Foundation?
How do I  use the date time picker to insert range and show the data in a table?
Leonardo
PaiChungAnswer
22-Sapphire I
You can store using ValueStreams (set property to logging is true)
and it uses QueryPropertyHistory services to retrieve the data.
You can use a DataFilter widget or a Time Selector widget in conjunction with that.
PaiChung22-Sapphire IAnswer
22-Sapphire I
