how to use date time widget to show data on mashup.
I have a mashup which has a led widget, and gauge widget and date and time widget  also have a thing  A which has a two properties -temp and humidity. I m storing this properties value in database in value stream table.
So now I want to show previous properties data on my mashup widgets led-temp, gauge-humidity by using date time widget. like when I select specified date and time in mashup  then that specified time date entry value want to show on widgets.
how can we do this?
Hi @Pratik_Aswale
You can store using ValueStreams (set property to logging is true)
and it uses QueryPropertyHistory services to retrieve the data.
You can use a DataFilter widget or a Time Selector widget in conjunction with that.
Hi @Surya_Tiwari
I do the same .
In mashup I m trying by using date time selector widget to show data in another widget of property but its not working.
