Sep 7, 2019 11:12 AM UTC
How to use geofence code snippet and bind it in google map
zyuan1Answer
Sep 9, 2019 4:02 AM UTC
The real Geofence is an infotable containing several Location data, and sent into the Google widget to draw a multi-angular space
https://www.ptc.com/en/support/article?n=CS225480&posno=2&q=geofence&source=search
The snippet code for geofence only have createCircularGeoFence and containsLocation.
First one is a infotable drawing a circle in Map (also bind in Map), Second service returns a Boolean fact.
zyuan15-Regular MemberAnswer
Sep 20, 2019 11:45 AM UTC
@sanjanabalaji
I just wanted to follow up to see if previous response was helpful for your question?
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question. If you are still experiencing issues, please do let us know your questions or concerns.
Vibhuti
