How to use google maps libraries like Drawing Library, Geometry Library and Places Library ?
  • December 9, 2016
  • 2 replies
  • 6616 views
Hi all,
Does anyone know how to use google maps libraries like drawing library , geometry library and places library in google maps widget in thingworx ?
There is a section of the Custom Extension Development Guide that talks about using custom widgets, and about using third party libraries in custom widgets.
Hope this helps!
On the metadata.xml you can replace:
<FileResource description="" isRuntime="true" isDevelopment="false" type="JS" url="https://maps.google.com/maps/api/js?sensor=false"/>
By:
<FileResource type="JS" url="https://maps.google.com/maps/api/js?sensor=false&amp;libraries=drawing,geometry"
  description="" isDevelopment="false" isRuntime="true" />
I hope this can help you.
done111-VisitorAuthor
Hi Ana,
Thanks for your help.
I have updated the metadata.xml file as you said.
But how to use that in the map ? I am unable to use it .
I added another data source to save the shapes and i call the function that i use to add the drawing option at the updateProperty.
But I think that you can added the code that you need at the afterRender, after having the map:
      this.map = new google.maps.Map(document.getElementById(this.jqElementId), options);
var polyOptions = {
  strokeOpacity: 0.9,
  strokeWeight: 2,
  strokeColor: zoneColor,
  fillOpacity: 0.50,
  fillColor: zoneColor,
  editable: true,
  draggable: true
drawingManager = new google.maps.drawing.DrawingManager({
  drawingControl: true,
  drawingControlOptions: {
   position: google.maps.ControlPosition.TOP_CENTER,
   drawingModes: [
         google.maps.drawing.OverlayType.CIRCLE,
         google.maps.drawing.OverlayType.POLYGON
  polygonOptions: polyOptions,
  circleOptions: polyOptions
drawingManager.setMap(this.map);
drawingManager is declared as global variable.
For my case, i just want to give the option to draw polygons and circles.
This is only for drawing the shapes.
I hope this can help you,
drawingManager
