How to use in my code. "FileTransferSubsystem"
I wish sending local file to thingworx server pc.
Is this right?
invokeService has timeout so I confused copy function timeout.
com.thingworx.types.collections.ValueCollection vc = new com.thingworx.types.collections.ValueCollection();
vc.SetStringValue("sourceRepo", "");//i don't know this
vc.SetStringValue("sourcePath", @"c:\\test");
vc.SetStringValue("sourceFile", "test.txt");
//elide
//elide
invokeService(ThingworxEntityTypes.Resources, " FileTransferSubsystem", "Copy", vc, 10000);
  • Copy
    public InfoTable Copy(java.lang.String sourceRepo,
     java.lang.String sourcePath,
     java.lang.String sourceFile,
     java.lang.String targetRepo,
     java.lang.String targetPath,
     java.lang.String targetFile,
     java.lang.Integer timeout,
     java.lang.Boolean async)
     throws java.lang.Exception
22-Sapphire I
When you do the configuration for the agent, you should be configuring repos (file storage locations) on the drive that will have an alias, that would be the sourceRepo
