pshashipreetham
how to use NOTLIKE query Filter ?
I am using the following snippet, to Query on FieldName Which does not contain the "Test Question" Text in the FieldName Data
var query = {
 "filters":{
 "type": "NOTLIKE",
 "fieldName": "Name",
 "value": "Test question:\\+*"
let params = {
	t: result /* INFOTABLE */,
	query: query /* QUERY */
// result: INFOTABLE
result = Resources["InfoTableFunctions"].Query(params);
Even though I get an INFOTABLE with rows containing "Test Question" in the FieldName "Name"..
Where did I do wrong?
Note: I have followed Query Parameter for Query Services (ptc.com) and Picked up the snippet from there
Try value as below,
var query = {
 "filters":{
 "type": "NOTLIKE",
 "value": "Test question*"
Try value as below,
var query = {
 "filters":{
 "type": "NOTLIKE",
pshashipreetham
Hi @Sathishkumar_C,
Thanks for the Quick response, but it is not working...
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Below code is working fine for me, I don't the list of values starting with "Audit"...  and ensure the field name once..
let params = {
	maxItems: undefined /* NUMBER */,
	nameMask: undefined /* STRING */,
	type: "Thing" /* STRING */,
	tags: undefined /* TAGS */
let entities = Resources["EntityServices"].GetEntityList(params);// result: INFOTABLE dataShape: RootEntityList
var query = {
 "filters":{
 "type": "NOTLIKE",
 "fieldName": "name",
 "value": "Audit*"
let params1 = {
	t: entities /* INFOTABLE */,
result = Resources["InfoTableFunctions"].Query(params1);// result: INFOTABLE
Always starts from the beginning, first I would check whether the "fieldName": "Name" really exists in the table. Pay attention to upper and lower case. If there is no name as a column, this is not taken into account here either.
Next I would test "value":  "%Test question%"  .
And if what you expect doesn't come out here, give a brobe with LIKE and see what comes as an answer now.
