How to use presciptive scoring with some constraints?
I use prescriptive scoring function to find optimized lever values with my model.
But I am wondering how to use presciptive scoring with some constraints. Some attributes(like quality) must stay in a properly range when min/max the goal. How can I do such works using prescriptive scoring.
I am investigating your question.
In the meantime could you kindly provide information about your Analytics Server version?
Thank you.
Asia
The 7.4 Guide states following:
For features marked as levers, the range of values that can be tested during prescriptive scoring is determined by the range feature at the time when the model is trained. New data can be uploaded after the model is trained, but for prescriptive scoring, the new range will not be considered in the lever metrics.
7.4 Guide - ThingWorx Analytics
Kr.
Asia
zhuwenxi12-AmethystAuthor
Thanks for your reply. So what you mean is that if I want to limit the feature's range, I need to filter the dataset with the range before building the model. Is that correct? And btw, I am using Analytics version 8.3.
Yes, Before building the Model.
Here is additional information.
Kr.
Asia
