How to use Splunk services in Thingworx
  • October 15, 2016
  • 2 replies
  • 5035 views
I Installed Thingworx7 and imported Splunk extension and configured SplunkThing with Port, UserName, Password.
I Installed Splunk4.4 in my local host.
Now how can I use Splunk to Add/Push Thingworx data.
I checked PersistanceProvider unable to identify newly created SplunkThing.
I am thinking to use Splunk for at least store and retrieve data.
I cant see any of Splunk services for adding of data through Splunk extension.
Please let me know how these operations can be done and also your thoughts for best practices.
Not relevant to above question - I posted same question through chrome and was unable to write anything in issue description, so posting same one again through IE. Not sure if it duplicated.
Hi Rajesh,
I am moving this to the Developer Community to get the right eyes on it.
Sorry for the posting trouble you experienced; I am working with Jive to resolve the issue - thank you for your patience.
Best,
Toby
22-Sapphire I
October 17, 2016
This should come with a Template that has services.
I believe you post data to Splunk and retrieve analytical results from Splunk through web services
If need be I can find some time to look into this a bit more in depth.
The data isn't 'persisted' in Thingworx for Splunk to analyze from what I remember, but just posted as desired to Splunk.
Thanks for responding Chung.
1. I referred to Splunk Partnership Ties Together Big Data & IoT Services - ThingWorx : ThingWorx
2.  Installed Splunk
3. Imported Splunk Extension from Thingworx Market and created ThingTemplate with Splunk configuration(Url, Port) in it.
Now Splunk 3 services shown as ; GetUsers, Search &  SendEvent.
I would like to understand how the data Push & Retrieve operations can be done.
Is this can only be done through Web services or any extension provided services can be used?
Looking at alternate storage -> Can I take the Extension advantage of Cassandra DB? e.g easy data push & retrieval operation like same as H2PersistanceProvider (Ignoring H2PersistanceProvider due to limit in size)
If any advise on alternate Thingworx & Big Data uses.
Thanks.
22-Sapphire I
October 19, 2016
So it looks like the SendEvent is used to submit incremental data to Splunk, that means something has to be defined for Splunk to recognize the event and you have to create a payload to submit with it. I pulled an example
// Create an InfoTable
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "StadiumEventData"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(StadiumEventData)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
// Add a record to the InfoTable
  result.AddRow({
  timestamp : timestamp,
  sourceType : "Thing",
  source : source,
  Temp : Temp,
  kWh : kWh,
  Sold : Sold,
  Venue : Venue,
  MachineType : MachineType,
  LocalTimeStamp : LocalTimeStamp,
  Capacity : Capacity
// send the record to Splunk
var params = {
  timestampField: "LocalTimeStamp" /* STRING */,
  event: result,
  type: "StadiumVending"
Things["LocalSplunkServer"].SendEvent(params);
So it looks like type is something that Splunk recognizes to then take the event and apply it to some analysis model.
Then the Search command is used to pull information from Splunk, this looks to be using Splunk Query code, here is an example I pulled.
var params = {
  searchExpression: "search sourcetype=StadiumVending earliest=-12h | stats avg(Sold) AS UnitsSold, avg(kWh) as kWhUsed by twsource",
  dataShape: "TrendByMachine"
// result: INFOTABLE
var result = me.Search(params);
var params = {
  searchExpression: "search sourcetype=StadiumVending twsource = SVM-01* earliest=-12h | stats avg(Sold) AS UnitsSold, avg(kWh) as kWhUsed by twsource",
var result2 = me.Search(params);
var tableLength = result2.getRowCount();
for (var x = 0; x < tableLength; x++) {
  var row = result2.getRow(x);
    // Add the row to result
  result.AddRow({
  twsource : row.twsource,
  UnitsSold : row.UnitsSold,
    kWhUsed : row.kWhUsed
