How to use window command in expression/validator
Hi all,
I'm trying to use window.print() command in expression but I'm getting error as "You can't use window in an expression". Is there any possible way to use window command in expression/validator ?
Thanks in Advance.
VR
22-Sapphire I
That unfortunately is blocked/not available.
I know location is available not sure what else is available.
Potentially you can create a custom extension to get the functionality that you need. (Not my area of expertise)
