How to visible navigation button in Mashup with different user
Hello Everyone, I'm newbie in Thingworx. I have a project with this platform.
How to get visibility in navigation button with different User?
For Example,
I want to build a Mashup with username and password login. Even, it can directly access to the mashup. But, the display is in read only mode or Navigation Button isn't available. Then, if User login with Username and Password, so the display will show the navigation button that they can operate it.
Anybody can help me with the step by step? Thanks
Best Regards,
Muhammad Alfin
PaiChungAnswer
22-Sapphire I
You can use a service to grab currentUser/currentUserGroups and return a 'true/false'
So you will need to create a service that uses one of these services and then compare that to  some reference to determine to output a true or false to control visibility
22-Sapphire I
Each widget has a Visible property.
Toggle that based on who is logged in.
Hello @PaiChung  Thanks for your response
Would you tell me about the service code? and  what kind of snippets of the service in the thing that have a correlation about current user then it will give the state value based on user?
Thank you very much
PaiChung22-Sapphire IAnswer
22-Sapphire I
