HTML in Text Field
I have a service which is giving me a string, but when I bringing it to the widget(Text Field) the html formatted of that string is showing up. Im using Thingworx 8.5.
Hello @RC_10864577
I tried the same use case and it worked fine for me. Can you please share some screenshots to understand it better ?. If possible can you please share the sample entity so that i can test and check it on my local system?
Hello @RC_10864577
