6-Contributor
I am trying Thingworx trial installation but it fails
The trial version installation fails and does not even keep the logs. I copied the log file just before it failed and it does not show any issues. attached the file. I,m using AWS EC2 with the right configuration and windows 2016 server version. Can someone help.
Hi @SM_9588025,
Could you please check the following locations for logs ?
- ${installdir}\installer\logs\
For example: C:\Program Files (x86)\ThingWorxFoundation\installer\logs\
- ${system_temp_directory}\ThingWorxFoundation_Failed_installs\
For example: C:\Users\<username>\AppData\Local\Temp\ThingWorxFoundation_Failed_installs\
Please note that there is a Foundation Windows Installation Guide for this type of installation : https://developer.thingworx.com/en/resources/guides/foundation-windows-install-guide
6-Contributor
Rocket_Max
The problem you are experiencing seems to be related to permissions, please make sure to refer to the guide correctly during installation.
BR,
Max
Support
Hi @SM_9588025.
If one of the previous responses helped you resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with the same problem.
--Sharon
6-Contributor
None of them helped
Support
Hi @SM_9588025.
Is this the first attempt at installing the trial, or did you have it running previously?
--Sharon
