I'm looking for thingworx java API that used external
Hell All.
I want to change thingworx field in external(exactly integrity lifecycle manager)
once integrity event happened, I will change thingworx field(such as true) for integrity event notification using thingworx java API.
Thank you in advance
Regards
BS
slangleyAnswer
Support
Hi @bson21.
If you are running ThingWorx Flow, there is an Integrity Lifecycle Manager that may be helpful (Flow itself may be helpful for what you want to achieve).  There is also a Data from Integrity Lifecycle Manager extension available on the Marketplace that you may want to check out.
--Sharon
raluca_edu
Could you please give us more details on this?
Raluca Edu
bson2112-AmethystAuthor
I want to notify thingworx to get integrity type information when integrity type state chaged.
so when event(type state change) happened, using integrity event trigger, I want to make thingworx work.
in my investigation, the way thingworx can know integrity event(state change) is REST API.
so I need to know REST API usage using java script(method integrity can act when event happen)
slangleyCommunity ManagerAnswer
Support
Hi @bson21.
--Sharon
