Jun 8, 2022 7:07 PM UTC
icon size limited on button widget without label
When creating a button with only an icon/ image displayed on it I find that the icon can only be enlarged to so far before it exceeds some allowable area.
With a blank label the icon, sized here to 100x100 pixels, becomes cropped.
With a label the icon is properly sized.
Is there a way to get image only buttons to have their icons properly sized without this cropping?
Nate_145Answer
Jul 23, 2024 4:58 PM UTC
The problem is solved! See https://www.ptc.com/en/support/article/CS420114
The following custom CSS should solve the issue of incorrectly formatted icon only buttons. Please adjust as appropriate for padding and allowable image size.
ptcs-button[mode="icon"]::part(root) {
padding: 10px;
max-width: 100px;
max-height: 100px;
Jun 10, 2022 5:31 AM UTC
@Nate_145 : Please try with https://www.ptc.com/en/support/article/CS328540
While using this, you need to define a custom class 'mycustomclass' on the button and use the below CSS instead of the one mentioned in article.
.mycustomclass ptcs-button {
ptcs-button-icon--dim: 70px !important;
height: 100px !important;
width: 100px !important;
max-height: 100px !important;
max-width: 100px !important;
min-height: 20px !important;
min-width: 20px !important;
background-color: transparent !important;
border: none !important;
padding: 20px !important;
Nate_14510-MarbleAuthor
Jun 15, 2022 3:53 PM UTC
This solution did work in Thingworx 8.5, but is not functioning fully on Thingworx 9.2.
Applying the custom class raw without any other changes results in the button formatting but the icon remains small. The blue border is from the focus style, activated here to show the button size.
I have attempted this solution with manual changing of the icon size in the Style Properties and the icon still becomes cropped.
Aug 3, 2022 8:23 AM UTC
Did you find a solution about this?
