Ignoring case sensitive in script fields
why is thingworx not persist change of case sensitive in scripts?
Recently I get an error in one of my scripts. My fault I had written Me.name instead of me.name. So I changed Me.name to me.name and saved the script and get the same error again. The change from Me to me will not saved. I must add an other char or line.
Hi David
I have tried to replicate this problem but cannot. I know on occasion from my experience, Thingworx Composer scripting console can play up when there are multiple instances opened of itself. Especially running new Composer alongside old Composer if you were to be editing the same Thing.
drichter1-VisitorAuthor
I tested it with the old composer. Its have nothing todo with other instances opened. The composer didn't save scripts when only the case will changed.
