Image Custom CSS
I want to make an image blackandwhite by CSS. Now I am trying to get a custom css work.
I made a CSS-class which works if i put it on the "img" type.
To get it work on the specific Image-Widget I need the correct selectors to reach the img.
Is there a documentation anywhere which selectors are available on which widget, therefore I don't have to go vie webdebugger and try all combinations?
.img_blackwhite .widget-image {
 -webkit-filter: grayscale(100%); /* Safari 6.0 - 9.0 */
But when I apply "img_blackwhite" as custom class on my image-widget it doesn't work. Are the selectors correct?
I also realized in the webdebugger that my style class is not applied anywhere. It was added to the dom under "mashup-styles" but not added to any element in the dom.
Can you help here?
Thanks in advance
I found my solution...
It seems to be not allowed to use an underscore in the styleclass name. After removing it the styling worked as intended.
.imgblackwhite {
Christian_S1-VisitorAuthorAnswer
.imgblackwhite {
