Implement Filters in Advanced Grid Thingworx
Hello
I want to implement Filters on My grid data , I tried to do it via some service but not able to do it . For search operation i have made a text box on the basis of one service.
Can anyone please help me what is the best way to achieve it?
Hello @RB_10191565
I have one confusion with your query do you mean to achieve search and filter in your advanced grid, if this is your use case please refer the following link
https://www.ptc.com/en/support/article/cs341658
Please let me know if this doesn't help you with your issue or you have any further concern.
Hello @RB_10191565
Just want to point out that the grid widget has its own filter and sort properties now that will filter and sort data in runtime.
Grid Property:
Column Property:
So unless you want to do the filtering/sorting server side, or using a chip filter for example I would recommend using this function instead.
Jens
