Import Data from Excel sheet to ThingWorx DATATABLE
@lschier  I followed your instructions for one of my requirement.
I am getting the error at the service -
Error executing service autoLoadMultipleExcelFiles. Message :: Could not initialize class org.apache.poi.xssf.usermodel.XSSFWorkbook. Would you be able to help?
Version of TW- 9.6.0-b85
KSMAnswer
Hi Vipul,
are you using any Extension like "Parsley" if yes then may be parsing excel sheet is missing. Plese check once your extension what are the services available.
ksm
Rocko
Looks like the POI classes are missing.
You either did not import the excelextension.zip properly, because those classes are contained in that, or you already have another, incompatible version of them installed, maybe due to another extension.
KSM15-MoonstoneAnswer
Hi Vipul,
ksm
Community Moderator
February 26, 2025
Hi @Vipul_Oswal
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
