import/export version compatibility
I assume it's possible to export from TW 8.0 and then import into TW 8.3, but if I wanted to export from 8.3 and then import into 8.0, would I encounter issues (ignoring for a moment extensions).  Would I simply need to take care to avoid using features that are only available in the later version?
More broadly, is there any guidance / matrix  available as to which versions play nicely and those that don't when importing / exporting entities between them?
Thanks to anyone that can point me in the right direction in this matter.
posipovaAnswer
20-Turquoise
Exports/imports are generally not backwards compatible and would require a lot of manual xml editing at your own risk - this would not be supported by PTC.
posipova20-TurquoiseAnswer
20-Turquoise
wmitchell1-VisitorAuthor
Ok. Thank you for the feedback.
Support
Hi @wmitchell.
If the response provided by @posipova answered your questions, please mark it as the Accepted Solution for the benefit of others with the same questions.
Thank you for using our Community!
--Sharon
