Import extension parser is too strict.
When I was developing some Java extensons, I noticed error while importing extension with exported entities and I believe it is a bug.
I have custom Java extension (ThingTemplate) with following configuration table:
@ThingworxFieldDefinition(name = "OutputType", description = "Type of the output string.", baseType = "STRING", ordinal = 3, aspects = {
  "isRequired:true", "defaultValue:text", "selectOptions:text:Text|json:Json|xml:Xml", "friendlyName:OutputType" })
Everything worked great, so I build custom logic in composer with one of the Things based on mentioned template. To make it reusable and easy to move it somewhere else, I exported my custom entities and created another extension dependant on first.
All the custom entities were imported to that new extension, but when I try to import extension I get this validation error:
Importing xml entities one by one manually works correctly, this probably should too?
Also exported entity has history of edits, that something you dont/want for you extension, is it possible to add checkbox that removes it during export?
I will send it in as ticket as soon as support portal is out of the maintenence window.
Regards JG.
jgabriel1-VisitorAuthor
Case number:
13780992
20-Turquoise
October 13, 2017
Jira PSPT-3948.
Removing aspect.selectOptions="text:Text|json:Json|xml:Xml" from the problematic entity and rebuilding the extension fixes the issue until the next export.
