Import failed
I am repeatedly getting this error in application log while importing project. And the import is getting failed. It is pointing " [1,018] " for media, users, modeltags as well. How to rectify this?
1. Unable to process import: Unable to update user: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]
2. [message: Unable to Invoke Service ImportSourceControlledEntities on SourceControlFunctions : Import Failed: Unable to update user: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]]
vi1Answer
when you observe message "Unable to update user: [1,018] Data store unknown error", you have to restart tomcat. After that, you can try to import files.
Latha
vi116-PearlAnswer
Latha
It is working now @vi1. But Importing project doesn't import DataTables right. But In my case it replaced all the DataTables(with data) to empty DataTables.
Now I have to export each and every DataTable through source control and import individually(from file, type-data) to get all the datas in DataTable.
1. How to stop replacing with empty dataTables?
2. Any other ways to export and import all datatables with all the datas?
You have to import Datatables data separately. In Import, select file->File type as "Data"->browse Datatable file ".twx". After selecting ".twx" file, click on import . You can see datatable entries after successful. You have to do one by one for all the datatables.
Latha
Okay Thanks. But while importing the project, the datatables(with datas) are getting replaced with empty datatables(zero datas). why? what is the solution for this ?
Datatable entries will not import when import the project. We have to do separately data after import all the entities. This is process.
Latha
