Ascherer17
Jul 18, 2025 2:17 PM UTC
Importing a Package/Extension With Transformed Properties
I created a Thingworx app that includes a Thing Shape containing a Transformed property (Platform Analytics enabled) based on another property in the Thing Shape.  I used the "Package" feature in my app's Project to export it as an extension.
When I attempt to import the package as an extension into my QA server, it fails with this error:
Error parsing /<PATH>/ThingworxStorage/extensions/temp/<PACKAGE>/Entities/ThingShapes/Entities.xml - make sure the file was not created with newer version of Thingworx: (370, 30): cvc-complex-type.3.2.2: Attribute 'aspect.dataCollectionMethod' is not allowed to appear in element 'PropertyDefinition'.
**PATH and PACKAGE are the path to ThingworxStorage and package name respectively.
Looking in the xml, the 'dataCollectionMethod' aspect it's referring to appears to be part of the Transformed property's definition.  I attempted to remove this aspect from the xml manually, zip up the files, and import as package again; I just get a similar error pointing to another aspect within the same Transformed property definition:
Extension Exception: Error parsing /<PATH>/ThingworxStorage/extensions/temp/<PACKAGE>/Entities/ThingShapes/Entities.xml - make sure the file was not created with newer version of Thingworx: (368, 30): cvc-complex-type.3.2.2: Attribute 'aspect.executionInterval' is not allowed to appear in element 'PropertyDefinition'.
I'm using Thingworx Foundation, Analytics Server, and Platform Analytics all on version 9.7.1.
Does Thingworx just not allow you to import Transformed property definitions or is there some other explanation?
slangleyAnswer
Support
Jan 20, 2026 9:53 PM UTC
Hi @Ascherer17
The following releases are now available, which should address this issue:
10.0.2
9.7.4
9.6.7
9.5.10
Please let us know if you will be upgrading soon and whether the issue is resolved for your use case.
--Sharon
Jul 20, 2025 3:32 PM UTC
Similar issue - "Extension Import Error for Distributed Subscription": https://community.ptc.com/t5/ThingWorx-Developers/Extension-Import-Error-for-Distributed-Subscription/td-p/905108
Rocko
Jul 21, 2025 6:18 AM UTC
I'd recommend a ticket with PTC Support for this.
Support
Jul 22, 2025 2:35 PM UTC
Hi @Ascherer17
With your approval, I'll be happy to open a case on your behalf.
--Sharon
Ascherer17
Jul 22, 2025 6:34 PM UTC
Thank you.  I went ahead and submitted a case for this.
slangleyCommunity ManagerAnswer
Support
Hi @Ascherer17
10.0.2
9.7.4
9.6.7
9.5.10
--Sharon
