importing project
As the project has 1000 entities, we exporting and importing using source control entities. The import is failed. The only error in application log is "Import Entities error: java.lang.Exception: Import Failed: PDFExport", "Unable to process import: PDFExport".
PDFExport is a Resource, why this needed for importing project? even import failed if i try importing PDFExport resource.
slangleyAnswer
Support
Hi @AP_9587236.
Are you importing the extension as a file or an extension?  You should first import the PDF Extension (selecting the Extension) option.  Then you should be able to import your project.
If you are unable to resolve this, we can open a case assuming you have support.
--Sharon
Did you imported PDF extension before import the source code? You have to import the extension first.
Latha
Can you please give me a link to download PDF Extension? What file it is?
I didnt get in PTC Marketplace.
