In DataShapes - what is the difference between effectiveFieldDefinition and fieldDefinition?
I'm building an extension that gets a DataShape and work with it fields.
In the JS code I'm getting two field definitions: one called effectiveFieldDefinitoins and one called fieldDefinitions.
What is the difference between the two?
Which one should I use?
