In HTML widget script tag is not working
Hi Developers,
Thorugh HTML text area widget i'm trying out the following html code.
<!DOCTYPE html>
<html>
<head>
<title>Axeda Developer Connection Simple Ajax HelloWorld Example</title>
</head>
<body>
<h2>Radio Buttons</h2>
<form id="mySelect" onchange="myFunction()">
<input type="radio" name="gender" value="male" checked> Male<br>
<input type="radio" name="gender" value="female"> Female<br>
<input type="radio" name="gender" value="other"> Other
</form>
<p id="demo"></p>
<script>
function myFunction() {
var x = document.getElementById("mySelect").name;
var form = document.getElementById("mySelect");
console.log("Hello world!"+form.elements["gender"].value);
document.getElementById("demo").innerHTML = "You selected: " + form.elements["gender"].value;
</script>
</body>
</html>
It works in w3schools editor as expected like if i make a selection, then the corresponding value of the selected radio button is displayed.
But when i try the same in  HTML text area widget, the script tag is not working.
The main objective is to allow the user to make a radio button selection and pass the selected value to a service or another widget outside the html text area.
Is the above use case possible with the existing html text area?
Saran
posipovaAnswer
20-Turquoise
As of ThingWorx Platform versions 8.5.0 , 8.3.10 , 8.4.6 , scripts no longer work for the HTML widgets due to security.
I think the way to do this in Thingworx is to add a List widget and set the widget property "View" equal to "Radio Button List". You need a service which binds data from an infotable to the list - for example the data could come from a Data Table or a static service.
When the user selects a row this will cause the Returned Data > Selected Row(s) on the service to change. Also the SelectedRowsChanged event will be triggered.
posipova20-TurquoiseAnswer
20-Turquoise
Support
Hi @SaranKarthick.
If you are satisfied that one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
