7-Bedrock
May 4, 2026 10:04 AM UTC
In Thingworx 10.0.1, In a grid widget, unable to trigger the "LinkClicked" event even after clicking on Hyperlink
Hello, I have a grid widget in Thingworx 10.0.1, and based on hyperlink click event I wanted to call a service. As I have multiple hyperlinks in grid, wanted to perform action based on column type. But when I am clicking on hyperlink in grid, this newly added event in Thingworx 10 “LinkClicked” event is not triggering. Any one implemented this? Your help is appreciated, Thanks in advance.
Mayur Kulkarni
Support
May 18, 2026 7:36 PM UTC
Hello ​@MMK_12345,
For further investigation, please provide the following information:
  • Which Grid widget type are you using?
  • How are you defining the hyperlinks in the grid?
    • Using Column Renderer = Hyperlink, or a custom renderer/state formatting?
  • Can you share a screenshot of the column configuration?
  • Are other grid events (like RowClicked) working correctly?
  • Do you see any errors in ThingWorx Application/Script logs when clicking the link?
Support
Jun 8, 2026 2:34 PM UTC
Hello  ​@MMK_12345,
Just checking in regarding the issue you reported. Has this been resolved, or are you still experiencing the problem?
If it’s fixed, it would be great if you could share what worked for you—it may help others in the community.
Also, feel free to reach out on community if you have any further questions/concerns
