increase font size
How can i increase my font size in Label widget ,TextBox widget,value display widget etc.. in Mashups??
For example, I bounded some of my property values to "LED Widgets",then i will use "Label widget" to label those
"LED  widgets" with respect to properties, but the labelled name looks too small when i run the mashup, i need to increase the font size of that Label, how can i achieve that???.
Akshay
mneumannAnswer
Most of the Widgets have "Label Styles" that you can use.
You will have to create a new Style Definition with the font-size and foreground-color you want and can then assign it to the Label.
If there's no Label Style, you can always just place a Label Widget and position it nearby - and style the Label with its "Style" property
mneumann16-PearlAnswer
Yeah, it's worked.
Thankyou!
Reagrds,
Akshay
