Influx DB - ThingWorx 9.0
Hi
    Is ThingWorx 9.0 supports InfluxDB.
Thanks in Advance
rjanardanAnswer
InfluxDB 1.7.10 is supported. Refer Database Options section in the System requirements document for ThingWorx 9.0
rjanardan16-PearlAnswer
Saranya_S1-VisitorAuthor
When i will try to create a persistence provider for influx db it was get an error which is in the screen shot.
Support
Hi @Saranya_S.
Did you follow these instructions for installing and configuring InfluxDB?
--Sharon
Support
Hi @Saranya_S.
I think this page from the Help Center should answer your question.
--Sharon
Support
Hi @Saranya_S.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
