Infotable Aggregate with Strings
Dear community,
I would like to use aggregation on string values, comparable to other languages, e. g. SQL. Easy example of an Infotable:
myKey stringValue
1 "mx"
2 "my"
2 "mz"
Any chance I can use the Aggregate function (or anything else) to get
myKey stringValue
1 "mx"
2 "my"
with "my" as the first or minimum value?
Thank you
Benny
PaiChungAnswer
22-Sapphire I
I would filter first on the String column and create a new 'grouping column' then do the aggregate with grouping
22-Sapphire I
Maybe some combination of a Query/Filter and Sort or Distinct
Check the Infotable functions
BennyB16-PearlAuthor
Thanks for your reply @PaiChung .
I guess I broke my example down too much. I do have more columns which indeed need a sum aggregation. But if I cannot process the string column Aggregate is not useful for me. So here my extended example closer to reality:
myKey numValue stringValue
1 4 "mx"
2 5 "my"
2 6 "mz"
Desired output:
1 4 "mx"
2 11 "my"
I have the feeling I need to iterate manually.
Thank you
Benny
PaiChung22-Sapphire IAnswer
22-Sapphire I
